The good ole A/C water leak...
Ok, I just bought a 97 accord sedan LX from a private party, and maybe 2 days later im driving down the road, make a sharp left turn, and here we are.. I know my way around a car fairly well (I think so) and It only does it with the ac on... its a perfect description of what the other threads are saying but I cant find anything as to what to fix it and where to look? I haven't inspected under the dash yet (waiting for a day off) but im concerned because it keeps my floorboards moist, and also its wet on both passenger and drivers side... but any guidance on where to start? what to look for? im determined to fix this and have a sunday off work here soon :D:D:shrug::hammer:
Thanks in advance |
It is likely the condensate drain outlet is blocked. Listen carefully for water sloshing about in the evaporator housing and possibly water entrained in the air flow.
How to fix? Suggest you try pushing a stiff thin rod (plastic wire tie strip, stiff wire, etc) up the rubber drain tube (lower firewall on pax side ~ 5 inches length). You will need to elevate on ramps or jackstands to access. Do not jam a very stiff wire and puncture the evaporator! Only modest force to hopefully dislodge the blockage and allow evap to drain correctly. The above may not work. Debris is likely to remain in evap box (not flow out the drain tube) and continue to block. In that case it is necessary to discharge the AC system and remove the evaporator, open evap box and clean the internal works of debris. It's not as bad a job as it sounds, but will require recovery/recharge of AC, and 3-4 hrs of DIY effort to remove evap, clean, and reinstall. Hopefully, you'll get lucky and debris is small and can be moved w/ pushrod. Of course you could always do w/o AC! I never liked that option. good luck |
Yes, I forgot to mention I believe it is building up to the housing because sometimes when I turn and the water leaks down, it makes the sound of like water being thrown thru a fan blade.. if you get what im saying lol like chopping water almost
Me, another option.
Find the drain hose in the engine bay coming out of the pass side - should be just below and to the center of the car from where the evap canister is. From below use a "wet" shop vac to suck the "gunk" out of the tube. I've use this on a few cars and also to clean out the house ac drain pipe. Then if you really want to dig in. After clearing the drain, there are some "spays" that you can buy that help with odor, mildew and that. You can do some reasearch/reading on those and decide if you want to use one. Just my two cents :shrug: |
(Post 360500)
Me, another option.
Find the drain hose in the engine bay coming out of the pass side - should be just below and to the center of the car from where the evap canister is. From below use a "wet" shop vac to suck the "gunk" out of the tube. I've use this on a few cars and also to clean out the house ac drain pipe. Then if you really want to dig in. After clearing the drain, there are some "spays" that you can buy that help with odor, mildew and that. You can do some reasearch/reading on those and decide if you want to use one. Just my two cents :shrug: Oh..... I don't know how to upload pics.. :( |
The blockage is usually right at the outlet fitting of the evaporator housing that connects to the drain hose. It's fairly small, perhaps 8-10mm ID.
PM's suggestion to use suction is a good one that should provide best chance for a cure. good luck |
Originally Posted by mattselen
(Post 360506)
4 Attachment(s)
Ok awesome, when I get off I'm going at it. If you can see the pics, it shows where I'm exactly It's building up and leaking. And the hose inlet
You want to leave the drain hose attached at all times to direct water to outside the firewall. Water coming out of the evap outlet nipple will drain directly on the ECU and TCU below!
good luck |
