h22 for $450?
i found an h22 motor thats super clean and comes with headers, intake, brackets, distributor, wiring harness, motor mounts accessories and ecu for 450!!! should i snag this up quick for my 93 accord se?
RE: h22 for $450?
It's too good to be true. It's probably blown apart inside.
RE: h22 for $450?
is a jdm engine or usdm? How may miles on it? Has been rebult or taken off a car which was in a acciedent?
RE: h22 for $450?
Sounds too good to be true to me as well.
RE: h22 for $450?
i thought it looked and sounded to good to be true as well thats why i consulted you guys.
what do you think i should do? leave it alone? |
RE: h22 for $450?
see if you can get compression test numbers from the seller. If it can turn over and hold pressure than it has some potential.
RE: h22 for $450?
what is the horsepower gains i should expect to see going from my f22a to the h22a both pretty stock.
RE: h22 for $450?
Around 40-50 extra hp from the H22
RE: h22 for $450?
about 50 or so HP. Look at wikipedia for these kind of answers.
RE: h22 for $450?
even if this engine was blown wouldn't it be worth more than $450?
