h22 build!
alright guys i dont post much on here but here it goes.
I was deciding on either doing a b18 turbo or an h22 no turbo and i ended up just deciding on the h22. If anyone has done this were you satisfied? im pretty sure ill be happy with my decision but i just wanna hear it more from you guys :] This is my first swap.. o yah i have a Manuel 95 accord ex f22b vtec. Am i able to keep my same transmission? i know i have to get new axles, and for my ecu? thanks guys :D |
a H22 swap has been done many many times. A B18 would require a lot of custom fabrication, and then not make enough torque to get the heavy accord going. You can keep you axles, transmission, and a lot of other parts. You will need a prelude ECU.
Yes I am very satified with my swap I am just finishing it up. I am having trouble with the clutch pedal, because I also did a manual swap on it too. You can keep the same transmission but it would be a good idea to get the prelude axles which are stronger than the accord axles with that said you'll need to get the prelude intermediate axle. good luck on your swap if you have any questions let me know since everything is still fresh in my head.
Cool! im so stoked to get this thing going! ima post pictures when it gets going
