H22 Head to h23 block
Hey everyone... im currently building a h23 motor to put into my 95 accord coupe. I would really like to do an h22 head though so i can incoorperate the vtech on the motor. 1 does anyone know where i can find an h22 head and does any one know what kind of work and money im looking at..
I think this will do better in the Engine/Internal section, so I'll move it. The DIY section isn't really for questions, it's for long detailed procedure write-ups.
h22a head
h22a power steering braket h22a thermostat housing h22a water pipe h22a water pump h22a lower crank gear h22a head gasket h22a plug wires h22a timing belt h22a head bolts h22a header and downpipe h22a intake manifold h22a top timing belt covers h22a cam gears you need to remove the oil control plug in the block before putting the head on. you will need to run wires and the ecu, for the vtec solenoid and knock sensor |
