-   Engine & Internal (https://www.hondaaccordforum.com/forum/engine-internal-11/)
-   -   h22 swap (https://www.hondaaccordforum.com/forum/engine-internal-11/h22-swap-15117/)
SteveO_f22a Jan 4, 2008 12:47 AM
h22 swap
Hey guys... How much HP will my f22 have once i swap to an h22 head and turbo(set at like 11-13)?
BlkCurrantKord Jan 4, 2008 07:02 AM
RE: h22 swap
Over 200hp
nafango2 Jan 9, 2008 04:21 PM
RE: h22 swap
210-220ish
i wouldnt recommend running that much boost on a stock motor though, at least get some forged rods/pistons first.
DA KID RYU Jan 9, 2008 11:40 PM
RE: h22 swap
Yea u talking about over 200 to 225 hp...
but u should keep ur psi at 6-8 psi keep it safe
you dont wanna mess it up u know.
BuntinBoy9 Jan 10, 2008 10:00 PM
RE: h22 swap
how difficult would it be to drop a h22 head on a f22 bottom and about how much
nafango2 Jan 11, 2008 12:39 AM
RE: h22 swap
whatever the head, valve cover, spark plug wires, distributor, water pipe, ECU, timing belt, thermostat housing and head gasket costs.
DA KID RYU Jan 11, 2008 11:44 AM
RE: h22 swap
How much horse power does the h22 head increase without turbo....
Why do u need new valve cover
ecu which one the f22b1 vtec one or the h22 one...
why do u need a new water pipe and thermostat...
nafango2 Jan 11, 2008 01:12 PM
RE: h22 swap
ORIGINAL: DA KID RYU
1) How much horse power does the h22 head increase without turbo....
2) Why do u need new valve cover
3) ecu which one the f22b1 vtec one or the h22 one...
4)why do u need a new water pipe and thermostat...
1) not enough to make it cost-effective. like 15. if that.
2) why do you think? (what does the valve cover bolt to...)
3) whichever head your using. Btw this is not easy, and since your even asking that question I would guess you wouldnt be able to do it at this juncture in time.
4) why do you think? different head...
DA KID RYU Jan 11, 2008 02:07 PM
RE: h22 swap
ORIGINAL: nafango2
15hp is better den bone stock....lol
not thinking of doing it myself or right now if that but i like to learn all this all....
curious to learn bout this topic....
So different head more friction aight
this is what is getting me confused sorry
your not using the same valve cover..
i got a f22b2 im not using the same one or what...
BlkCurrantKord Jan 12, 2008 10:11 AM
RE: h22 swap
^ Kid - start reading and getting to know things before asking such general questions.
Go over to www.honda-tech.com- sign up, read, read, read. That's the best advice I can give you. If you don't understand it, re-read it again.
