H22 VS F20B
I want to know which engine will do better on a all motor race....
which engine will do better when the compression is down n turbo with 10 psi... |
RE: H22 VS F20B
ORIGINAL: DA KID RYU 1) I want to know which engine will do better on a all motor race.... 2) which engine will do better when the compression is down n turbo with 10 psi... 2)Neither |
RE: H22 VS F20B
so which engine will hold down more..
turbo charged f22b engine or f20b n/a set up |
RE: H22 VS F20B
both when you resleeve them
RE: H22 VS F20B
ORIGINAL: DA KID RYU so which engine will hold down more.. turbo charged f22b engine or f20b n/a set up |
RE: H22 VS F20B
So if i was to turbo charge my f22b2 engine i would get more hp out of it den if i was to get a f20b engine...
i really like the blue top.. plus its an accords type r engine so it will drop directly with out no problems or new motor mounts. And its sexy knowing u got 200hp out of an engine.Plus the internals are pretty strong.just compression ratio sucks... how much can u get out a f22 engine with over 20 psi... an estimate please |
RE: H22 VS F20B
400-600whp
RE: H22 VS F20B
WOW thats pretty nice number thanks blkckord
will da engine handle dat much psi |
RE: H22 VS F20B
willthe engine handlethat much psi |
RE: H22 VS F20B
if you build it up to handle that much
