-   Engine & Internal (https://www.hondaaccordforum.com/forum/engine-internal-11/)
-   -   h22 wont mount up (https://www.hondaaccordforum.com/forum/engine-internal-11/h22-wont-mount-up-43415/)
guru350 Oct 17, 2011 03:20 PM
h22 wont mount up
hey fellas i have a problem my h22a wont mount up in my 95 ex ...i have a prelude driver side mount a 93 5 speed f22 tranny with mount (h2u5)and stock back mount and bracket ..... the problem is that when the back mount is bolted in the tranny hits the frame and the tranny mount wont mount up
question # 1 do i have to have a cd5 tranny and mount because they are different ????
question # 2 do i have to change the back bracket to and h22 one if there is a difference ???
my boy has a 95 p2u5 tranny and mount would that solve the issue ??
g22cd5 Oct 17, 2011 06:09 PM
you should be able to use your front and rear mount. Then use the prelude driver side mount (which you have) as for the trans use the mount that corresponds to the trans you are using.
