H22a
is it worth going from a F23A1 to a H22A? and would all of my aftermarket parts i have on my car work with the H22A. and wut is the power gain of doin this? thanks
RE: H22a
stock a h22a swap has 200hp and 161 lbs-ft of torque. that right there is already better than a stock f23a1 engine. the all aftermarktet parts would just make the h22a better, if they all would work....idk that.
RE: H22a
how much is the h22a
RE: H22a
How much kind of depends on how you want to do it. A lot of places sell the h22a with both manifolds, tranny, ecu, wiring harness and maybe a few other things like ac condenser etc. The more the kit includes the more expensive like everything for $2500 to $3500. You can just buy the engine and save some cash but then your are going to have to turn around and buy the things you didn't get originally, maybe hit the junkyards? For an idea of prices look up h22a on ebay.
RE: H22a
theres a place right here in Greenville that sells jdm engines. he sells h22a for around 2 grand. and that swap comes with.
Transmission Engine Wiring Harness Engine Wiring Harness All required Cables ECU Distributor Complete Intake Manifold Alternator A/C Power Steering Pump All Brackets and Sensors Shiftlinkage ($75 extra) |
RE: H22a
http://rimsandthings.com/images/engines/honda_h22a.jpg
here's a pic of the engine. |
RE: H22a
noting from everything you have
Tsudo N1 Catback Exhaust System DC-S Headers JDM Cold Air Intake AEM Tru Power Pulley Kit L.E.D Neons Outside L.E.D Neons Inside Ground Wires OBX Sparkplug Wires 17' BSA Rims Carbon Fiber Tail Lights two 12inch MTX s |
RE: H22a
I'm swapping an H22a into my 90 Accord (f22a). What youneed toget with the H22a is the tranny, ECU, wiring harness, distributer,fuel rail,andintake manifold. I MAY have missed an item or two (someone correct me if I did), but you do not need the shift linkage (if going from 5spd-5spd), AC, alternator, or power steering pump.
Mine isn't done, but my buddy swapped out a turbo Jspec k22 (i think) for a turbo H22a in his civic, and this is what he told me when I asked about doing my swap. Also, I believe the mounts will line up, so no welding should be required. What I did was look for a cosmetically crappy 93 Prelude VTEC (dont know the exact model of the car). They have H22a's in them, and if the car is a piece of crap, but mechanically is fine, then you can buy the car for cheap and pull out whatyou need. |
RE: H22a
no such thing as a K22
H22 F22 thats it i think... |
RE: H22a
I have never heard of a K22 either... K20 and K24, yes.
