H22A OBD2
I have a question if I buy this http://www.sunrisejdmmotors.com/engi...d=6&page=1 it comes with Complete Engine - 5-Speed Transmission - ECU - Intake Manifold - Exhaust Manifold - Distributor - Alternator - Starter - A/C Compressor - Power Steering - Throttle Body - Clutch - Fly Wheel - Pressure Plate.
Basically almost all I would need for the swap. But I have one question because I have a reg. F23A1 Auto tranny accord, this swap will just replace all that with a H22A1 and a 5 speed tranny? |
RE: H22A OBD2
You would need a few more things, such as the 5spd engine mounts. And the H22 is a cable tranny, and I believe the f23 is a hydraulic tranny, so you would need the shift linkage off a older Accord. Thats all I can think of right now.
RE: H22A OBD2
hm how much is installation roughly?
RE: H22A OBD2
To pay for a shop to do that kind of job? It would be insane, I would think at least 2k in labor alone.
RE: H22A OBD2
lol screw that then :/ lol I'll just save up for another car like a Ek hatch or a crx for a little fun :)
RE: H22A OBD2
ORIGINAL: live2rice You would need a few more things, such as the 5spd engine mounts. And the H22 is a cable tranny, and I believe the f23 is a hydraulic tranny, so you would need the shift linkage off a older Accord. Thats all I can think of right now. |
RE: H22A OBD2
find the P13 OBD2 ecu w/ no immobilizer, or swap to OBD1. Have fun wiring that up. |
All depends on the shop you take it to for labor, I know most Fseries accords book around 18-19 hours for long block swap, so averaga shop time is 100/hr, easy math on hourly rate. And I would guess they will flag more hours for a swap depending on how they do it. Certianly to install new pedal assemply for the five speed.. Have fun.
Originally Posted by silence007
(Post 268275)
sorry, when I put my seach in an attempt to find an answer without starting a re peat thread this was in the top of the list. Maybe a moderator should remove it or something, or design a way for it not to be on a current search. Glad to know someone will point out a date over sight before helping with an enire new thread.
