Help!!!!!
i have a 1994 accord and it has a blown up d15b7 in it how can i put a motor out of a 1995 honda accord back in it what all will i need off the 1995 thanks
d series in a heavy accord? I think you have your engine codes mixed up. D series would be a hella expensive swap and it would be WAYYYYYYYYYYYYYYYYYYYY under powered for heavy accord. Check your engine code again...
That is what I thought but I was going to leave it up to the guys with more experience.
If you have the normal F series engine from a 94 putting in a F series from a 95 is super easy. They would be the same and have all the same sensors on both and everything will bolt right up. |
if I'm not mistaken the b7 is the mini me swap. I would have to look it up but I'm almost 100% sure.
But as for a D series in a accord? That just floors me...cus who would spend all the money to swap a tq less D series into a 3000lbs car? It would be utterly pointless |
