HELP engine runs till 3k rpm then spudders
Hi Everyone my motor today started doing this weird thing... i turned it on and it usually doesnt struggle to turn on but today it cranked over a few more times than usual... then i started driving and when i was about to shift into second gear the motor spuddered then on second gear i watched the rpm gauge and i noticed that it wasnt going over 3k rpm it kinda reminded me of a speed or rpm governer because it revs then stops revs then stops but wont go past 3k rpm :(
can anyone help me figure out whats wrong with my car pls!!!! thanks in advanced for your help. |
RE: HELP engine runs till 3k rpm then spudders
Clogged cat
hmm maybe check intake and your exhaust? Could it be a clogged injector or fuel system?
Get a check-engine light? If so, have it read atAutoZone or someplace like that.
If not, check whether the bulb is burned out for your check-engine light. |
Thanks for all the replies everyone.
i dont have a cat.... i removed it months ago and put in a obx high flow cat... but i think its just a test pipe i could see straight through it. i did get the check engine light a little after i installed the obx. but the car ran fine untill yesterday when i turned it on, i had let my little sister borrow the car and she drove it for a few months without problem... i checked the oil and it was DIRTY so i changed it last night and cleared the maintenance light. reset the ECU and still no rev past the 3k... should i try a fuel injector cleaner? |
Are you getting a check engine light now?
yes its code P0335
:( would this cause the engine to not rev past 3k |
crank position sensor.... thats what the code said... and it costs like 179 bucks!!!! ahhhhh.
lol but anyways i hope replacing this will solve my problem.... but its weird though it was working fine and then i start it up and run it normally and it screws up... thats just wrong to me. also has anyone ever heard of the ecu going into "limp mode" ??? |
turns out some fkn animal bit the wires and it wasnt making contact... those fkn animals!!!!
purring like a kitten now :) |
