How do you take off the engin-cut
Hi ,
I have a 92 accord,automatic, and I want to do some stockcar with it. I want to know how do you take off the engin-cut. thanks Max |
RE: How do you take off the engin-cut
You want to do what? Take off what? You mean the fuel cutoff?
after market fuel control... Hondata prefereably...
no uncut the rpm so i can get the max rpm
yeh its a fuel cut... max RPM for ur engine is low maby 8 grand... Kseries valves float at 9200 im not sure about urs... upgrade ur valvetrain and cams... new springs retainers and titanium valves... install all that... and u might get to 10 but u will need to make sure everything else can take it... stretching a rod would be bad!!
i wouldnt go much more then 8k rpms you really dont want to run it to the 10k range because you will lose the stability of the engine
are you talking about fuel cut off? governor? from what i remember, only subaru's dont have them.. you can take it off but your risking damaging the engine, tranny, diffs.. etc.. jst to be able to go beyond redline and max out your speedometer which in a '92 accord, i doubt you can do unless the engine was taken care of really well and runs like new.. possibly mods.. i dont even think the '92s could go past 110-120 stock?
So no one is going to tell him how to remove the Rev Limiter? I mean, everyone is assuming 1. He'll actually do it and 2. He's not intelligent enough to know that redlining an old car is a bad idea. I still think he is entiteled to the knowledge tho. IMO
ORIGINAL: theBrewMeister So no one is going to tell him how to remove the Rev Limiter? I mean, everyone is assuming 1. He'll actually do it and 2. He's not intelligent enough to know that redlining an old car is a bad idea. I still think he is entiteled to the knowledge tho. IMO |
