How to replace axle to trans. seal?
I have a trans. oil leak between my new drivers side inboard axle andwhere it slides into the transmission, 95 Accord EX , 2.2, auto, abs.
Are there any special tools necessary to remove and replace seal? Is this a straight forward job, other than removing the axle? |
RE: How to replace axle to trans. seal?
I replaced the seal today. I used a small screwdriver to seperate the outside of the seal with the transmission, and then continued around the seal using a twisting motion of screwdriver until it fell out. I used a large socket with a long extension to replace new seal.
| All times are GMT -5. The time now is 10:25 AM. |
