I need some direction
I have decided to swap my f22 out the 94 and put in a h22 the only thing is i wanna switch it to a 5spd what needs to be done I am starting to pull the engine today I want to do it all myself the Haynes manual sucks it telling me take everything off the engine
Hi Member
2 Attachment(s)
I would run out to my car and get to AutoZone and go to the book shelf and buy this book that I keep telling everyone about in here.
Red Cover says...HONDA ENGINE SWAPS...BOOK # z93 WheelBrokerAng |
Thanks
Thanks I will definitely go and pick that up thanks.
1. 5 speed transmission (F22, F23, H22, H23)
2. 5 speed starter (90-02 Accord 92-02 prelude) 3. 5 speed shifter assembly w/ shifter cables (90-97 Accord, 92-96 Prelude) 4. 5 speed drivers side axle (your year accord, but from 5-spd version) 5. 5 speed intermediate shaft (your year accord, but from 5-spd version) 6. 5 speed clutch pedal assembly (90-97 Accord, 92-96 Prelude) 7. 5 speed brake pedal arm (90-93 Accord, 94-97 Accord) 8. Clutch master cylinder w/ reservoir and lines (90-97 Accord 92-96 Prelude) 9. Clutch line from Clutch master cylinder to clutch dampener (90-97 Accord 92-96 Prelude) 10. Clutch dampener assembly (90-97 Accord 92-96 Prelude) 11. Clutch line from Clutch dampener to 5 speed tranny (90-97 Accord 92-96 Prelude) 12. Clutch line from 5 speed tranny to slave cylinder (90-97 Accord 92-96 Prelude) 13. Slave cylinder (90-97 Accord 92-96 Prelude) 14. Clutch (90-02 Accord 92-01 Prelude) 15. Flywheel (90-02 Accord 92-01 Prelude) 16. 5 speed mount (Your year, 5-spd version) 17. 5 speed mount bracket (go to Honda - tell them to look for the bracket that is welded on the car - part is S.O.P and costs 15-25.00) (see notes) 18. MIG WELDER (see notes) 19. BOLTS: 8 Flywheel Bolts, 6 Pressure Plate Bolts, 3 Intermediate Shaft Bolts, 1 Long Tranny Bolt |
