Idle Problem
Do you have any pictures showing the IACV location and removal steps? What is the best cleaning agent?
I think I need to clean mine as the engine idles a little rough when the AC is switched on. From what I am reading, the engine RPM should stay the same or increase a little when the compressor load is applied. |
I moved to your own thread for clarity.
See Online Manuals post in DIY forum for 94-97 Accord Manual for download. This has pics and instructions. Check youtube for videos. Use throttle body cleaner to clean. Clean IACV, IACV screen, IACV inlet/outlet port on throttle body, throttle plate front and back, and throttle bore around throttle plate. good lukc |
