Idle Screw
Where is it...
RE: Idle Screw
On the 93 I believe it's screw #1 in the picture, so the lower right hand side as you face the opening....
[IMG]local://upfiles/3079/5D900C3D4E054ECA86C6D18384919C65.jpg[/IMG] |
RE: Idle Screw
Nasty ,,you are a real nice guy ...and i mean it..... replying to Roknazn,, after the way he cordially asked for help.. ..
Wow.....I sure hope that it does not rub off on other members reminds me of a guy that came into my shop and threw the keys of his car on the counter and said ( Oil Change) that's all he said, he had no appointment,, I gave him the keys back and told him i was too busy and could not do it untill the following day .. |
RE: Idle Screw
Well put ‘desert’, but here a pix for 92-95, but what year is the car in question…??
RE: Idle Screw
Desert and Nasty, I appreciate all the help and tech info that u have given me. The reason I asked this Question is because I been having problems with the honda surging at Idle. It idles about 650 rpm but when Im at idle at a stop light for awhile sometimes it goes down to 400 and want to died...So IDK what is going on. Im in the process in trying to replace the Heater Core and Bypass Line this weekend and see it that all works out.
Thanks Again Anthony |
RE: Idle Screw
ORIGINAL: droopy128 Well put ‘desert’, but here a pix for 92-95, but what year is the car in question…?? I'd probably set the warm idle from 7-900 rpms, replacing that heater core so your temp sensor is more accurate (since your fluid won't be leaking) may help.... good luck on that heater core those things suck.... luckily your carpet is already soaked so you'll be a little less concerned about it.... |
RE: Idle Screw
Haha...:D BTW Any Tips? on Upon Remove of the Heater Core? I will try to do Step By Step Write Up on it..:D
RE: Idle Screw
the biggest tip I can say is disconnect the hoses at the firewall in the engine bay first and plug them (use a drip pan unless you want to kill off some stray animals...) that will keep it the least messy, also, when doing jobs like this I like to always have a few things on hand just in case.... (keep in mind I've never had a professional shop to work in.... usually I'm on the ground outside in the sun or snow or whatever....) Zip ties (all sizes), Duct Tape (yeah, laugh it's funny but it's saved my bacon before), Electricians tape, Manual or instructions, a spare hose clamp or two, drip pans, a spare ride to the parts store if you need it, beer, and a full day set aside... that's how I roll....
RE: Idle Screw
Well, So far I got all the new bypass hose on, Disconnected the Heater Hoses, Removed Radio, Cluster, Dash Trim and A/C and Heater Control Unit. I also unbolted the Dash and moved it out almost 2 feet. I cant take it out of the car for some reason..I will work on it more Tomorrow or Saturday..
Thanks Anthony |
RE: Idle Screw
Well, I just finished replaceing the Heater Core and All is good..I believe..haha But I still have the Surging Idle. I bump the idle to 850-900rpm. Factory Recommends 700 +/- 50 rpms. Do ya'll know what is wrong?
Thanks A Bunch Anthony |
