-   Engine & Internal (https://www.hondaaccordforum.com/forum/engine-internal-11/)
-   -   Ignition Coil question (https://www.hondaaccordforum.com/forum/engine-internal-11/ignition-coil-question-55449/)
rklettke Jun 23, 2013 10:37 AM
Hi there, I just bought my first Honda. It's a 2002 Accord SE with a 2.3l I4 VTEC. Sadly it's an automatic... Anyways, car is in pretty great shape, but the previous owner who only owned it for about 4 months doesn't know any of it's history.
So I'm doing a tune up. Just did the oil this weekend and now, because I'm stationed overseas, I need to order a full tune up online. Problem I'm having is the ignition coil either has the little spring at the end or a solid contact.
Here are the two I mean:
They are all a variation of those two. Question is, which one should I buy??
Thanks.
poorman212 Jun 23, 2013 11:35 AM
Two things....usually if the coil isn't bad, I would not replace it as part of a tune up....again just me.
Next, memory tells me the coil has a solid contact.
stang99x Jul 1, 2013 10:51 PM
Replacing coils that aren't bad, would be like replacing a distributor that wasn't bad. You could do it, but you'd just be lining a parts companies pocket. Nowadays, change the plugs, air filters, maybe flush the tranny at the due mileage. Not much else needs be done. (besides regularly scheduled fluid maintenance)
