injectors
i have some 290 cc injectors can install them in my 91 accord lx and do i have to reprgram my ecu
RE: injectors
Hi..
What you will need to see about is hooking up to a fuel management system and a Tuner with knowledge of the fuel system. Your engine drivers are designed for the stock fuel system and your raising the fuel pressure or changing to the larger injectors can leave the computer Out of calibration..This should answer your ????? Later... WheelBrokerAng[sm=americanasmiley.gif] |
RE: injectors
thanks for the info WheelBrokerAng now all i have to do find a tuner in this area
RE: injectors
Your welcome for the thank you...
Go to your local big stereo shop and ask one of the guys who will have a Honda or and Evo sitting outside and he will more than likely have some tuners shop name to pass on to you. Stay with us here in the forums and invite any of your other Honda Brothers and Sisters to come in and be with us.. Great Luck With Your ride.. WheelBrokerAng |
RE: injectors
Your stock ecu will not control larger injectors properly. You need a piggyback or standalone EMS, Hondata will let you control larger injectors with a stock ECU.
