JDM MOTOR SWAP
How hard would it be to swap a jdm motor into a 96 accord lx? Would everything bolt up right? And I wouldn't have to change the ecu or anything,would I? Another mechanic told me that
RE: JDM MOTOR SWAP
yep that mechanic was right...kinda. it depends on what jdm motor your swapping in. if its a jdm f22, then it bolts right in and you dont need to change the computer. but....changing the computer is the easiest part, and if you wanted to put in a jdm h22a you would want to change out the computer. if you tried to swap a b series motor into it, it would not bolt right up. if your swapping out motors, spend the little bit of extra money and get an h22a, but before you put any jdm motor in, make sure you change the timing belt and the water pump.
RE: JDM MOTOR SWAP
RE: JDM MOTOR SWAP
I want the same motor that is in it right now,just a jdm version.To me swapping a motor defeats the whole idea of tuning.Your supposed to work with what came in the car,then work with it.Hell,if I wanted to do a motor swap I would put a chevy 350 in it,then blow everyone away.
[Deleted]
[Deleted by Admins]
RE: JDM MOTOR SWAP
yea your thoughts right now are warped. it would be rediculous to spend 10 or 15 thousand dollars to make a 350 fit and make it rear wheel drive just to have a 70-30 front to back weight ratio. the h22a bolts right into the engine bay with no modifications for a reason.....the fastest accord of your model....the type R came with an h22a right from the factory. what your saying is the equilvalent to having a 1970 barracuda with a slant 6 cylinder in it and you have a 426 hemi in the garage that you dont want to put in because it wasnt 'supposed' to be in there. you and i both know the 440 or the 426 are the engines to go in there. its the same thing with your honda. honda did the same thing with your intake system.... if they did NOT want you to put a high performance intake on it, they would have put a MAF or some other crap in the intake to make it difficult, but its just a tube! your car was engineered to facilitate high performance driving and its up to you to either leave it the way it is or utilize the full potential.
RE: JDM MOTOR SWAP
I just completed a JDM swap. I too stayed with the F22A but as luck would have it the JDM motor I got must have been out of a 1991 SE (..that was above the EX then) or from an EX-R. The intake system is substantially different with a vacuum operated 4-8 bypass. I did open the intake and the exhaust a lot, but as of yet the SE / EX-R FI isn't installed yet. How much performance gain can I expect from this FI system? Did the 1991 EX-R and or SEs come with an H22... Is the block labeled H22 vs F22?
RE: JDM MOTOR SWAP
the se's did not come with the h22 check the stamp on your engine block on the front, it should say f22a6. you can expect some serious performance out of that engine. you already saw the butterfly intake manifold, what you havent experienced is the two stage timing system, which is half of what the vtec system does
RE: JDM MOTOR SWAP
How does it differ from the lowly LX? Is that difference all in the head? What kicks the two stage timing system? how is it activated / functioning. I didn't expect to buy anything but a replacement F22A1 but are the innards (piston, rods, crank and cam) different? To simplify this a bit... What makes an F22A6 a '6???'
RE: JDM MOTOR SWAP
Not really adding to the mix but just asking a question: I know an h22 will bolt right up in my 94ex. Now if I get my hands on an ob2 motor and computer, is changing out the ecu just as easy? Or is there more wiring needed? Also, what is the chance an h23 is going to fit in with no issues? Will it still bolt up with just wiring needing to be done. Also, most importantly I am guessing is that I defenitely want to use prelude axles correct? From what I have read, they are the same length and hub set up as in the accords, is that true across generation gaps?
Just wondering[sm=smiley31.gif] |
