MAJOR PROBLEM!!!
Sup ppl, I hav a serious problem (i think) wit my accord. It was running fine until the other day as I was drivin down a steep hill my ABS light went on and then for some reason my RPM's and MPH seem to just drop to zero when im cruising and then go back up to the normal RPMs and MPH. It just cuts out for a second then its normal. This keeps occuring as I keep stopping at lights untill i got home and parked my car. The next day when i started it, everything was fine...The ABS light was off and the car ran normally but as I was driving back home, the ABS light went on again and the same problem occured again. I was wondering if anyone had a similar problem or know the cause of this problem. I drive a 2000 Accord V-tec 4 cylin. Thx ppl |
RE: MAJOR PROBLEM!!!
Sounds electrical so start simple and check all your ground wires and battery terminal connections/cleanliness.
The negative terminal does seem to get a lil corrosion but i just cleaned it. I havent checked the ground wires yet but i will. I was thinking about driving the car around until i get the same problem and then take it to Autozone to have the code read so I know whats going on.... |
