Manual tranny for an h22 from f22???
I was wondering if a transmition from my f22 engine ('97 accord lx coupe) would work on an h22 engine? if yes, what possible mods that need to be done to make it fit?
RE: Manual tranny for an h22 from f22???
F-series (not f20c) and H-series trannies should be a bolt-up affair.
It should bolt right up. The taller gears will make it slower than an H22 tranny though.
You will want to verify this, but the fitting for the slave cyl might not match up.
thanx everyone
The slave cylinder is bolted onto the transmission so it will be fine. You might have to use the F22 fly wheel.
ORIGINAL: 7thGen The slave cylinder is bolted onto the transmission so it will be fine. You might have to use the F22 fly wheel. |
ORIGINAL: 6thgen ORIGINAL: 7thGen The slave cylinder is bolted onto the transmission so it will be fine. You might have to use the F22 fly wheel. |
yea the f22 tranny will bolt right up. dont use it unless your running turbo with a vtec controller. youll notice when you shift with it that the rpms drop well below stock vtec point with the f22 tranny.
lightshow |
ORIGINAL: lightshow yea the f22 tranny will bolt right up. dont use it unless your running turbo with a vtec controller. youll notice when you shift with it that the rpms drop well below stock vtec point with the f22 tranny. lightshow But yeah, thanx for the advise. |
