mistery oil
hi..
I have a 96 honda accord with a 4 banger. What would cause alot of oil to get into where the spark plugs go. any feadback will be helpful. |
RE: mistery oil
Here is one good answer from experiance....
The crankshaft seal-when worn to long-leaks the oil down into the plugs which usually fouls the plugs and gives you a bad stutter in the motor every so often... Check it out and see if I was right... WheelBrokerAng[sm=pimp.gif] |
RE: mistery oil
/agree
