MISUNDERSTANDING
i completely misunderstood everything that i was reading and thought that the CD6 Accord SiRhad the F20B in it. after taking another look i realized that was the CF4 Accord SiR. after realizing that i believe i am going to go for what the CD6 Accord SiR actually had in it and go with the H22A. anybody know if it was the 92-96 H22a or was it the 97-01 H22a please let me know so i can get my 97 Accord SiR conversion underway thanks
RE: MISUNDERSTANDING
It was the 92-96...but not the USDM H22.
thanks. is the h22a also made for racing NA or is it possible to turbo it?
Pretty much meant for N/A...
You can turbocharge anything. You just have to make sure the engine is meant/built for it. |
The CD6 accords used the 96-00 H22a1, because it uses the OBD2 system instead of the 92-95 OBD1 engines. The engine are great for turbo, I'm in the midst of building my very own. You just have to get some books on building and moding honda engines, most have hundreds of dyno test of almost every configuration, so you can find what would be best for what you want to do.
Three books that I have used alot are:
1 Chilton or Haynes manuel 2 Honda Engine Swaps by Aaron Bonk 3 How to Build Honda Horsepower by Richard Holdener |
ORIGINAL: Carbon91EuroR The CD6 accords used the 96-00 H22a1, because it uses the OBD2 system instead of the 92-95 OBD1 engines. The engine are great for turbo, I'm in the midst of building my very own. You just have to get some books on building and moding honda engines, most have hundreds of dyno test of almost every configuration, so you can find what would be best for what you want to do. |
