-   Engine & Internal (https://www.hondaaccordforum.com/forum/engine-internal-11/)
-   -   More powerful engine 1998 ex (https://www.hondaaccordforum.com/forum/engine-internal-11/more-powerful-engine-1998-ex-28739/)
antlachance Oct 21, 2009 04:02 PM
Hey guys I'm a relativly new honda owner. I want to put a new more powerful engine in my '98 accord ex xoupe. It currently has a 4cyl ULEV VTEC engine. Any ideas of what engine I should be looking for?
antlachance Oct 21, 2009 05:22 PM
nobody?
JimBlake Oct 22, 2009 09:16 AM
The ULEV has a whole ton of differences in the wiring harness, much different from the 2 other 4-cylinder engines.
You can search for posts about swapping a H23 engine, but you'll need to convert your car's wiring harness to match a non-ULEV.
For a lot of work & money, you can swap in a V-6 & 6-speed from Acura CL-S or something like that.
95tuner Oct 22, 2009 02:30 PM
Oh, man. The 2.3L ULEV is kind of a rough swap. If it were a '97 or earlier, then an H22 would be easy. An H23, though, is more tech specific, and will hardly yeild any more power. If I was in your position, I would install a T3/T4 turbo. There would be less headaches for sure. I hope this helps. Good luck.
