-   Engine & Internal (https://www.hondaaccordforum.com/forum/engine-internal-11/)
-   -   My engine is leaking oil, need help asap (https://www.hondaaccordforum.com/forum/engine-internal-11/my-engine-leaking-oil-need-help-asap-4569/)
chevync20 Aug 17, 2006 03:36 AM
I just recently purchased a 1990 Honda Accord LX that I bought to drive back and fourth to work and after only 300 miles it seems to have a serious oil leak and need help. I just replaced the oil plug and filter and was hoping that would help, but to no avail. It appears to be leaking right above the oil pan right where the bottom pully is, i assume this is the timing belt housing. There is oil seeping down from in there, what could this be? Seal on the crank? Please someone help me so when i take it to the shop they dont run around and tell me its something else.
lightshow Aug 17, 2006 04:13 AM
RE: My engine is leaking oil, need help asap
yea if its coming from there its the seals in there. get them fixed quick and make sure they put the special retainer in there. you can easily ruin the motor if the seal pops out, which it sounds like it did. dont drive the car anymore have it towed
YeuEmMaiMai Aug 17, 2006 07:27 AM
change the timing belt and have then replace the balace shalft seal and install the retainter kit for it
HondaRacer4Vtec Aug 17, 2006 01:25 PM
just curoius how many miles on the car?
chevync20 Aug 17, 2006 03:33 PM
190k but the previous owner told me he had it changed in the last 5000 miles, but they might not have replaced the seals, so i quess to the Honda shop it goes
lightshow Aug 17, 2006 04:56 PM
no they might not have put the retainer in there. problem is now that the oil has probably splashed on the timing belt which will reduce its lifespan considerably.
mbo1985 Aug 17, 2006 07:04 PM
Yeah, you don't want to mess around with thtat belt. If it has been exposed to oil, i'd say you're better off replacing it.
chevync20 Aug 18, 2006 03:42 AM
I think im just gonna get the whole service done to be on the safe side. I would feel more comfortable knowing all of that will be good for years to come. I will let you guys know what it is when they tear into it on monday
