need flywheel help
Ok i just had my flywheel and clutch installed and my car doesn't accelerate like it use to i put a 11.9 pound flywheel in from the stock 21.9 pound flywheel and a exedy oem replacement clutch. It just doesn't take off for POO is it that the clutch needs to break in or do you think there is something wrong like when i take of just like a noraml person it feels fine but when i go to get in it it just doesn't do anything i need to replace the speed sensor cables on the trans because the odomoter doesn't work could that be the problem i really need this fixed
RE: need flywheel help
Is the clutch slipping?
no the clutch isn't slipping i found out that v-tec will not work right with out the VSS working so i fixed the wires that came out of the sensor and now it is about 25% faster than it was. The new flywheel helps out alot
