NEED MORE HORSEPOWER!!
ive got a 2001 accord v6 coupe. im looking for some ideas about how to increase the horsepower that would be a little less expensive than a turbocharger. any suggestions??
RE: NEED MORE HORSEPOWER!!
Best and most reasonably priced option would be Comptech Supercharger, custom turbo kit on a V6 could be a nightmare on the pockets.
a good set of ceramic headers-and a larger mass flow air sensor-gains 15-20hp? BEETs
just do the basics.. but usually basics adds up to a turbine cost. but then if you want turbo.. you should already have done the basics. Intake, headers, exhaust. then maybe.. ignition coils, wires, and iridium spark plugs should help. an upgrade to the intake manifold is good. Pulley set and cam gears help also.
Those are reasonable gains if he already has a supercharger and a higher psi pulleys for it. The stock sensor reads up to 10-11 psi. The comptech doesn't run that high anyway.
i have practically same thing.. an 02 accord v6 coupe.. was wondering who has one.. that they have modded and what they have done.. what kind of times do you get.. and hp numbers...??
Okay my friend here is my first suggestion and the quickest way to make QUICK horse power.
Get yourself a K&N Intake kit Typhoon #691203TS and you will get youself a Quick 10.1 Horsepower@5950 rpm. Cost is low and the performance . These are proven increases from K&N and are from their dynamometer testing...See picture of one below.. Hope this helps you out ... WheelBrokerAng ORIGINAL: bullet099 ive got a 2001 accord v6 coupe. im looking for some ideas about how to increase the horsepower that would be a little less expensive than a turbocharger. any suggestions?? [IMG]local://upfiles/22/1AB65AB746444962BD5BCFF8E5A2C7F2.jpg[/IMG] |
