new member 1986 accord lx
Old Jul 24, 2013 | 10:21 PM
fordmudvayne's Avatar
Default new member 1986 accord lx
I am currently the owner of 3 honda accords. I have recently acquired 2 1986 accords. One is an lx-i and the other is a lx. do the heads on these interchange? My lx is in way better shape body wise. The lx had a timing belt failure at 30mph. Gonna open her up this weekend and inspect the damage. Any advice would be awesome. thanks alot.
Old Jul 25, 2013 | 05:28 PM
Cool....another 3rd gen (86-89) owner
Welcome to HAF.
Pretty sure (?) the heads are different
Old Jul 25, 2013 | 09:19 PM
well the lx had belt failure. at about 25mph, hope there isn't too much damage.
Old Jul 26, 2013 | 05:06 PM
Well you could always put a new belt on and then do a compression test......might have gotten lucky?
Old Jul 27, 2013 | 12:34 AM
Welcome new member and Thank You for joining the HAF...
Old Jul 27, 2013 | 04:48 PM
thanks alot, well i removed the valve train and did leak down test, all hole running pretty consistent 120 psi. i put straight edge on valves and they flat. i looked at my timing belt and 6 teeth have been sheared off but belt is still intact. So it looks promising. think im gonna get timing belt kit and give her a wirl.
Old Jul 28, 2013 | 05:28 AM
Once you have the timing belt back on, spin the motor over a few times using the crank bolt. Watch the valve springs to be sure they "return", want to be sure they open and close - sometimes the "stem" will get a slight bend in it - causing a valve to stick.
May 18, 2011 02:20 AM
Chris Bowden
Apr 2, 2009 07:38 AM
stomachfluid
Jun 21, 2006 05:35 AM
86accordlxi
Nov 13, 2005 04:09 AM
86AccordGuy
May 18, 2005 12:44 AM
