New Oil Pan Gasket - Slight Distortion?
I just replaced my oil pan gasket, 95 accord, 4cyl, auto and went by the recommended procedure:
cleaned surfaces, 3m spray adhesive on block and block side with a genuine Honda gasket (worked great),RTV High Temp on short sides and torqued to 10 foot lbs, from inside out. However, the rear side of gasket is slightly distorted. Kind of like jelly coming out the sides of a sandwich, but it isn't more than 1/8 of inch beyond the block and pan. Does this sound normal? |
RE: New Oil Pan Gasket - Slight Distortion?
I've seen it happen more than once, as long as the majority of it's still in there and it's making a good seal and doesn't continue to work it's way out I'd leave it.
if u ever get worried just look at it every now and then and see if its leaking
I just changed my oil pan gasket and it did the same thing, but I have a feeling my torque wrench reads a little low so i overtorqued the pan bolts. Not really sure, though.
you tightened the pan bolts too tight.. As long as it does not leak you should be ok,, just keep on eye on it
ORIGINAL: deserthonda you tightened the pan bolts too tight.. As long as it does not leak you should be ok,, just keep on eye on it |
mine still doesnt leak, and its been a good 3k miles.
ORIGINAL: razcob ORIGINAL: deserthonda you tightened the pan bolts too tight.. As long as it does not leak you should be ok,, just keep on eye on it |
i just used one of those flexible scrapers, took it right off.
I don't believe I have the bolts too tight because only the rear side of gasket is distorted and the front side is perfect.
