New Question Up For Your Entertainment...
Here is a new question for you to put on your thinking caps for...
Your trans-axel will not downshift with your accelerator pedal pressed to the floor------What is your Answer... WheelbrokerAng[sm=pimp.gif] |
RE: New Question Up For Your Entertainment...
Downshift detent cable has come loose under the hood.
Usually you have to downshift it. Being a stick shift...its kinda required.
I've never heard an auto tranny called a trans-axle, just manual. But if it is auto..i would say its...either bad clutch packs or torque converter. :P |
[sm=imsorry.gif]I'm sorry....wrong answer....
One more try my Friend.... WheelBrokerAng |
Yes my Forum Friend ...there is what is refered to at the Honda Dealer a
Automatic Transaxel. Reference as follows...all vehicles come equipped with either a five speed manual or a four speed automatic transaxel. Due to the complexity of the Automatic TransAxel which takes specialized equipment necessary to perform most service operations , routine maintenance, adjustments and removel and reinstallation of your TransAxel should always left up to a dealer service department or to an automotive or best ; transmission repair shop...And By The Way...I dont work for either one of those type companies[sm=smiley16.gif] Hope that this helps out your answer..Now get me a good answer,Thanks! WheelBrokerAng[sm=smiley14.gif] |
Transmission fluid could be low.
A/T control unit faulty? Any codes? Flashing D light? |
| All times are GMT -5. The time now is 04:20 AM. |
