newbie here ... 95 accord Swap
i was wondering if anyone can help me with this ...i have 95 accord LX sohc non-vtec AT .. if a swap to a sohc vtec AT .. will i have to change the ECM? or any other parts?
Yes, you'll probably have to swap the ECM to use the one matching the engine.
Hello Member:
1 Attachment(s)
Try this tomorrow or when ever there are open..
Call AutoZone in your area and ask them to look up the ECM for both cars..if they have the same stock numbers...then you will be alright... WheelBrokerAng |
Thanks
Thanks for the replies .. i just found this out ...
"Requires engine, ECU and OBD1 to OBD2 wiring jumper harness" but i have no idea where to get the wiring jumper harness ... the only thing i found was "OBD2 to OBD1" wiring harness which is the opposite of what i need.... any suggestions???? :confused: |
