not taht im a noob, but...
ive used the search function many a time, and cant exactly find an answer. what other performance mods are really WORTH doing and spending money on after i/h/e? OTHER than nitrous or turbo....cams? pulleys? fuel system? cam gears? underdrive?
[align=left] [/align] |
RE: not taht im a noob, but...
Nitrous, Turbo kit, S/C,cam/cam gear, tune, 5spd swap, engine swap
Any or all of the above. |
ORIGINAL: BlkCurrantKord Nitrous, Turbo kit, S/C,cam/cam gear, tune, 5spd swap, engine swap Any or all of the above. |
Switch to OBDI and run Hondata
Crank pulley
how do u switch to OBDI?
yeah, im with 02blue. whats involved in switchin to OBD1?
a harness, a new computer and potentially losing some comfort functions of the car ...... possibly more ..... aka, not worth the trouble, especially for a 6th gen AT.
you really cant switch a 6th gen AT to obd1 for what ive found that whole pesky AT controller being needed
you could do a H22 headswap with a solid-state distributor, knock sensor, and put some higher compression pistons in. youll get about 200hp with 11:1 compression setup.
