Oil changing and factory warranty
Hi all.
I have never been one to tolerate dealers and their inflated labor charges but I am concerned that if I don't have a dealer perform the oil changes, this may void my warranty. I have read that this is not the case. I also have read that if I use the correct viscosity and a factory oil filter anyone can do the oil change. Can someone confirm these questions? If I can go anywhere, can someone recommend a vendor in the southern New Jersey area who is well respected by many? :cool:Thanks! |
Originally Posted by Biffy44
(Post 362478)
Hi all.
I bet the 2015 owners manual calls for 0w-20 oil... Also it's probably printed on the oil-fill-cap on the valve cover.
Brand-names for oil is like asking about politics or religion... You can search for stuff here or in the General-Tech section. You will probably find that all 0w-20 oil will be some kind of synthetic. |
Originally Posted by JimBlake
(Post 362506)
I am pretty sure that all of the "jiffy lube" type service sites carry this grade of oil but do they carry the "OEM spec filter" that shipo recommended in his post?
Does anyone have recommendations on where to go or not go? Should I purchase my own "OEM spec filters" online and if so does anyone have a recommendation on that? |
I would be highly surprised if Jiffy Boob didn't carry an OEM spec filter for virtually all Hondas; that said, I wouldn't trust that company to change the oil in my lawnmower much less any of my cars.
Originally Posted by shipo
(Post 362522)
(Post 362524)
So is Honda service all you will use?
Especially with a new car (such as your 2015) it is suggested that you either purchase the oil and filter yourself (keeping the receipts) and witness the service being done or have the service completed at a Honda dealership. Something else to keep in mind is that Honda recommends replacing the drain plug seal when changing the oil |
(Post 362524)
If it comes to pass I'm unable to perform my own oil changes, I will use a small independent local shop to do the actual work (I will still buy the oil and filter). |
Quickie oil change places are like ebay. It's hundreds of different individual businesses. You might find one that's OK. But if they consistently take the time to be properly careful, you wonder how they make enough money to survive?
And I change my own oil so I can't really help you find a place. |
