ok is it all right to use seafoam as much as you want
i thought i read (i am pretty sure i read) that someone said you can use as much seafoam as you want to as advice. it was to someone new. can anyone validate that? i thought you would want to use it sparingly cause its pretty concentrated stuff. works really well for sure. its bugging me that i couldn't find it under the search icon. i thought whoever wrote it had a funny way of putting it. anyways, any thoughts on using seafoam on every fill up?
RE: ok is it all right to use seafoam as much as you want
1/3 in the gas tank, 1/3 in the PCV valve, and 1/3 in the crankcase (oil) a week before changing the oil.
Seafoam is a stout solvent and should be used only as needed. If you want to keep the entire fuel system clean this is meant for every fill up and works:
http://lcdinc.zoovy.com/c=ArktATq4SE...uct/FPPLUSGGAL |
yeah, i have only used in the gas tank. but, thanks for the advice.
also, i think it was you that said you can use seafoam as much as you want. i am not sure was it you? but, anyways its a great product!
