performance chips
what are some good ones that will work with a 96 4d accord with a f22?
please send sites if possible. thank you |
RE: worth it? slr performance chips?
no no no no
and NO unless you mean these kind of chips: http://poland.usembassy.gov/poland/i...frito_logo.jpg |
Venom VCN-2000 ..... but it's a little more than a "chip" ..... and it needs a bottle hooked up to it.
hondata, but once again more than a chip
L2R: Have you seen the one that I posted? It's a dry nitrous controller that pulses the fuel injectors so that it has the effect of a wet system. Also does progressive spray. Now that's a power chip ..... but it's the size of a small amp.
no i havent, i havent really looked into nitrous that much though. And dont know much about it. the differance between wet, dry, and direct port is about the only nitrous terms i know.
Your car would be so sick on a 75 HP wet shot!!!!
ORIGINAL: falkore24 Your car would be so sick on a 75 HP wet shot!!!! i'm thinking 12:1 or 13:1 compression with skunk2 pro 2 cams. about 260whp. |
Can 13:1 run on pump gas? What happens if you get a bad tank? I wouldn't go that high on a DD. IMO, 11.5:1 is a good limit. Then I'd say a 50 shot.
yeah you can run 13:1 on 93........i prob wouldnt would prob get 105 that they sell at the track.
and the accord isnt going to be a daily driver for much longer |
