Performence Chips
Is there anything for accords that is like superchips, etc?
RE: Performence Chips
yea theres actuall chips that can be soldered into the ecu and then theres jet chips, which are alittle box that you install.
Where can you get these chips?
if you have obdII you most likely wont find a premade chip..... but either way you have solder work if you do it yourself, and if you break any connections or screw up in general that means you will need a new ecu.
