Power windows and sunroof dont work.
The battery on my Honda accord 98 was disconnected and reconnect but my power windows and sunroof now dont work. The locks and mirror control work fine. Any help is appreciated.
Ive tried reseting the multiplexer by doing this: "Put the key in the ignition, move the intermittent wiper control to the middle possition and then turn the key on. just to clarify it's the ring that controlls the intermittent wiper speed and not the int / low/ high switch. What this does is it resets the multiplex unit that controlls the accessories such as the power door locks. This problem usually happens once the battery has been removed or disconnected and reconnected. Every once in a while the multiplex systems lock up. Especially on the 98s. That's how you wake em up. " but no luck. Ive also checked the fuses and they seem fine. |
nvm fixed the problem the power window fuse was moved to the wrong spot.
