Pulley?
RE: Pulley?
i've heard those give you no type of gain in HP or Torque what so ever so i really don't know what to tell you.if you looking to sup your engine,resleeve and boost.
RE: Pulley?
The accessory pullies don't get much of a gain. The crank pulley is where the gain is. I had the full 3 pulley set from UR. If you are on a tight budget and want a pulley, go with the crank pulley from UR. If you want the full setup, still go with UR.
HPJ: Pullies, like a lightened flywheel have no potential to make horsepower or torque. They reduce the parasitic inertia caused by the rotational mass. A lightened pulley or flywheel allows the engine to rev up and down faster allowing faster acceleration, but peak #'s don't change. The area under the curve does grow and that's what matters. |
RE: Pulley?
ok yeah i knew i wasnt aimen for numbers but i mean im not going to be running at those higher numbers anyways but the faster acceleration i could use and thats what i thought a pulley set would do ... thanks for backin my thinkin up... also thanks i will definently look in to the UR crank pulley i appreciate it.
RE: Pulley?
They sure do look purty though!
RE: Pulley?
yeah but i would rather them be butt @$$ ugly and do their job than be all nice lookin and do squat... as of right now i dont need to show off my engine bay lol
RE: Pulley?
so pulley's help...wow i learned something because i was told by a person on this forum that they are worthless but of course that person will not be mentioned[&:]
RE: Pulley?
I think they help a bit .... only in acceleration though, a dyno won't show it.
RE: Pulley?
as falkore mentioned light weight pulley will help u rev faster allowing for faster response... no extra anything what so ever.... but taking 300lb of your car doesn't add HP but does make the car faster...(get my point?)
Edit: forgot the question mark...ooooppppppsssss! |
| All times are GMT -5. The time now is 09:09 AM. |
