rebuilding my h22a4 head
i am planning to rebuild the head on my h22a4. These are currently the parts i have on order.
Skunk2 Camshafts Skunk2 Cam Gears Skunk2 Valve Springs Skunk2 Valve Set (Intake & Exhaust Valve) Skunk2 Titanium Retainers APEXI Head Gasket APEXI VAFC II VTEC Controller What do you guys think? Am I getting everything i need? Should i change any of the parts? |
RE: rebuilding my h22a4 head
Use an OEM headgasket and ditch the VAFC. Send it out to get a basic/minor port and polish and have them install your parts for you unless you're doing it yourself.
I'd go with a thermal insulating type head gasket and E-manage instead of the V-AFC. Do you plan to do the bottom end too? Nitrous or FI? If so, I'd at least add a block guard if it's the open deck type. Port/polish ..... the head and the IM. Also, a larger TB with the IM matched to it.
as of right now i am just planning to rebuild the head. The block is gonna come later on. The reason i said the VFAC is because i planned to stay N/A instead of going turbo. Thanks for the advice. Always willing to take suggestions.
I have the V-AFC ..... it's good for tweaking the tuning, but if you want to really make more power, the E-Manage allows you to adjust injector maps and I think it lets you advance the spark timing. These are major functions that a V-AFC can't do.
ORIGINAL: falkore24 I'd go with a thermal insulating type head gasket and E-manage instead of the V-AFC. Do you plan to do the bottom end too? Nitrous or FI? If so, I'd at least add a block guard if it's the open deck type. Port/polish ..... the head and the IM. Also, a larger TB with the IM matched to it. |
thanks for the info falkore ill research it further. how much did u pay for your V-AFC? and how much is an e-manage?
BCK: this wouldn't work? http://www.honda-performance.com/info-lv2.asp?id=237
I'm thinking ahead! He said that rebuilding the block will come later ...... if that means forged pistons and rods, then the block guard will allow him to push a 150 wet shot of nitrous ...... that's F&F style! Also, for $75 how can you go wrong? |
sounds good. lol thats what i need to start doing, PLANNING AHEAD!
He could push the nitrous with out a block guard. Sleeving is a better option than those block guards.
| All times are GMT -5. The time now is 03:50 AM. |
