..rough idle
hello all, my first time posting on this forum so here goes. i have a 97 accord ex 4cly and i just got it like two weeks ago. the engine bay and everything about the car is pretty damn clean. no oil and min dirt everywhere. but i noticed that at idel in my driveway its alittle rough. now i know this isnt my Acura TL but still i don think its suppose to be that rough. any sugestions u guys might have on what the cause my be. thanks
RE: ..rough idle
Probably the rear motor mount gone bad. Mine does it too, no money to get it fixed right now. :(
RE: ..rough idle
i think ima use some lucas oil stuff tonight and see how that goes. proly gonna check the air filter too.
RE: ..rough idle
Easy stuff first. You could try to reset the ECU and/or adjust the idle control valve on the throttle body.
RE: ..rough idle
my idle when i come to a stop it sounds to high,i am not really a mechanic but where will the idle control be located at? if you could send some pic...thanxs
RE: ..rough idle
Check out this thread in the DIY section: https://www.hondaaccordforum.com/SUR...m_46125/tm.htm
