Royal Purple and 10 HP??
I was watching Trucks the other weekend and I saw them dyno an engine on regular oil (i think it was a 350)then the same engine on Royal Purple and it gained 10 hp and like 9 ft lbs. Just from the switch...Do you think this is limited to that engine or could it benefit our motors???
RE: Royal Purple and 10 HP??
might benfit a little bit, but big V8s have a lot more to oil than our 4bangers.
you might get like 3-4 hp. if your lucky. you can get a small amount of hp by simply using synthetic oil, doesnt really have to be royal purple. |
magik isnt a 4 banger ;)
On Bobistheoilguy Royal Purple has not shown any outstanding used oil analysis'. A few were good and some acceptable but no really great ones. Not many there use it so the UOA's are fewand that may account for themediocre showing. I find it overpriced for what you get but that is just my opinion. If I were going to change to synthetic right now the choice would be Pennzoil Platinum. I use Mobil 1 currently and have a large supply so it will be a while before I change brands.
I use the Mobil 1 also Rick and will more than likely use it most forever..by the way .. did you get my PM this morning?
Pm me with an answer after you research that subject alittle... Thanks WheelBrokerAng |
ORIGINAL: nafango2 big V8s have a lot more to oil than our 4bangers. |
ORIGINAL: RTexasF On Bobistheoilguy Royal Purple has not shown any outstanding used oil analysis'. A few were good and some acceptable but no really great ones. Not many there use it so the UOA's are fewand that may account for themediocre showing. I find it overpriced for what you get but that is just my opinion. If I were going to change to synthetic right now the choice would be Pennzoil Platinum. I use Mobil 1 currently and have a large supply so it will be a while before I change brands. For what it's worth, after I did a quad-tranny fluid change and an oil change with Royal Purple, my car is dying. I don't attribute this to the fluids, just coincidence I guess ...... and there's a theory floating around that the tranny fluid changes killed it. |
