should i get some fuel injector service?
ive tried cheveron fuel injector cleaner (synthetic) and i didnt feel a difference at all, so i think i should get some fuel injector service because i know my car has more potential power to it. Not in aftermarket parts, but in restoring it so it runs like new
RE: should i get some fuel injector service?
I'd run some seafoam through the engine and gas first and see how that does
where can i get that?
honda dealership? |
Most auto parts stores carry it, there is also a write-up on it in our DIY section
what did the chevron service entail?
huh?
sorry...i misread it...thought it was a service, and not just a bottle of cleaner. my bad.
you should try LUCAS Complete Fuel treatment. Its the best one out there
probably its more okay to look for service..do you have manuals? that stuff can help you throughout..but as long as you knew its all about technical work..a honda accord fuel injector is nothing but an electronically controlled valve. It is supplied with pressurized fuel by the fuel pump in your car, and it is capable of opening and closing many times per second and the amount of fuel supplied to the engine is determined by the amount of time the fuel injector stays open called the pulse width.. the injectors are mounted in the intake manifold so that they spray fuel directly at the intake valves. A pipe called the fuel rail supplies pressurized fuel to all of the injectors.
Best bet is to remove the injectors and have them ultrasonically cleaned.
I've done my 87 Merc Sable and 89 Mazda 626. Both had around 120k. Some disassembly required. I replaced the valve cover gaskets on the Sable while waiting for parts. Service performed here: http://www.witchhunter.com/ Fast turnaround, before and after flow documentation, $90 for 6 including shipping. Magic performance restoration. 626 more difficult than Sable. Careful not to drop parts in manifold openings. |
