So i seafoame'd my car and nothing happen....
no smoke, car didn't stall while doing it did i do it in the right spot? if not where do i put it , on a 03 6cyl car, i used to have a maxima and on it i just poured it down the pcv valve
what i did was unhook the cpot i circled hooked to the metal pipe https://lh3.googleusercontent.com/_o...-29-03_787.jpg |
Maybe the engine was already clean?
nvm i figured out had to put it in the intake manifold
need to use the vac. line for the intake mani. You can also take your intake off and put seafoam in a spray bottle and spray it on the Tb
Usually you take the line off the brake booster to put Seafoam in.
Originally Posted by engtaz
(Post 233151)
