-   Engine & Internal (https://www.hondaaccordforum.com/forum/engine-internal-11/)
-   -   Subframe removal (https://www.hondaaccordforum.com/forum/engine-internal-11/subframe-removal-11299/)
mck52689 Jul 27, 2007 02:07 PM
Subframe removal
Im not a genius when it comes to accords but i need to remove the sub frame.... what will happen if i take it off, or move it for a few minutes time.
Shadow1992 Jul 27, 2007 06:28 PM
RE: Subframe removal
Subframe?Accords are unibody construction....so what piece are you talking about?
deserthonda Jul 27, 2007 07:21 PM
frt beam ?
rear beam ? where the p/s rack is mounted ??
4GVN1 Jun 14, 2012 04:19 PM
Subframe removal-HELP!
I am going to have to replace the rack and pinion as well as the subframe where the bracket that holds it in place on the drivers side, the bolt sheard off from the subframe and now is loose. Any input is greatly appreciated!
2003 Honda Accord EX
Ttripp Apr 11, 2018 02:37 PM
I'd like too jump in here and ask a question. Im getting ready to swap out my engine on my 99 honda accord (v6 vtec) I've been told that there isn't enough room for just the engine to cone out the top and to just drop the engine and trans together from bottom. In your comment to someone else you said the frame is unibody. Someone told me you need to remove subframe or k frame? You have any info that will help me do the swap thru the bottom? Only done top engine removal on rear wheel drive before.
