This sux!
A friend of mine from the St Louis honda club was trying to replace my timing belt on my 94 EX. He encountered a very tight bolt and could not get it out. Im pretty bummed now since i have to pay labor costs out theBUTT* He did fix my drivers side driveshaft however.
let me guess the crankshaft bolt wouldn't come off? VERY common issue and quite a few posts on here about that... sorry to hear you're going to pay a ton of labor but in the future let us know, there is a full write-up in the DIY section and tons of info on how to get that bolt off yourself....
Is it to late to tackle the job yourself? already got it in the shop? If so then it would be really upsetting to realize that you could have done all of that yourself... pay someone $20.00 to break that bolt loose then it's all on you and save $530.00
Same here... This was the exact same problem I have. Now I have to pay 550 to get it fix but also Extra $60 buck so they can find out that 1 ground wire was loose from the ECU to make the car run again. Not sure this is BS to get more money or what....
Anthony
Anthony
