Temperatue Gauge/Brakes
I have a 2002 Honda Accord 4door EX. Recently when I idle at stop or parkingthe temeprature rises very quickly. I have checked all my fuses and the cooling fans do turn on yet it still rises. There is plenty of coolant. Any suggestions? I was thinking about getting the radiator flushed.
Also, anyone have a recommendation on where to get my brakes looked at/replaced. They have been squeking a while and I believe it's time to get them replaced. I heard from so people to not go to Brake Check Plus. |
RE: Temperatue Gauge/Brakes
Check your thermostat it could be bad. Same thing use to happen to me when I had an Oldsmobile Omega(heap) 2 different cars but another place to start.
Have you checke d the collant level? Do the fans work?
yes, coolant level is where it needs to be and the fans turn on no problem.
are the fans spinning in the right direction? (that could be the problem if u removed it recently and installed it back.....happend to me once (very embarrasing)) good thing i found out myself...
