Is there a way to remove the top speed limit on a 2009 Accord 3.5L V6?
Old Jan 12, 2010 | 11:47 PM
claggie's Avatar
Default Is there a way to remove the top speed limit on a 2009 Accord 3.5L V6?
Forgive me if this is already answered, but my searches didn't find it. Can one remove the 125 mph limit on a 2009 Honda Accord 3.5L V6? Not that I would be interested in doing that!
Thanks for any replies.
Old Jan 13, 2010 | 12:31 AM
jasonfridlund's Avatar
Wink p.s. the limit is set at 135
take it to an auto shop. they will probably have a tuner that can do it. if not, they will probably know somebody who does.
On a side note: It is possible, but with 5 or even six gears, the engine is still in the upper half of its rpm band. you may only get 10-15 more mph out of it.
is it worth the extra 300 dollars or so for the tuning?
also remember that with the possibilty of going more than 150mph, you need better tires than the ones that come stock on the car. They are only rated to 149mph(V). so get some W or Y rated tires that are much grippier.
one other point: honda limited the top speed for a reason(and it's def not legal reasons) if not just tire expense, the aerodynamics at 155mph or so, are such that a car w/out any splitters, diffusers or FUNCTIONAL spoilers (not the spoilers you get from honda..they just look pretty) might lift off. it doesnt sound possible, but remember what a 150mph wind would feel like to you. it would knock you off your feet.
I'm not saying don't, I'm just saying that the reason the fastest cars in the world are so expensive, is because they need to be to withstand the forces of that speed.
Be safe,
Jason
Old Jan 13, 2010 | 04:08 AM
Assadi's Avatar
Hello,
I would like to do the same thing with my car, its Honda Accord EX-L V6 4 doors 4AT. Currently it reaches max 218km/h, and i believe since the car speed meter is maxed to 260km/h, then it should be safe to reach there. I also would like to know if there are any tuning chips or upgrades available & tested for this model.
Regards,
Assadi
Old Jan 13, 2010 | 08:44 AM
Briggz's Avatar
Almost A Senior Member
Originally Posted by Assadi
i believe since the car speed meter is maxed to 260km/h, then it should be safe to reach there. i
No offense, but that is very flawed logic.
Old Jan 13, 2010 | 08:56 AM
... and i believe since the car speed meter is maxed to 260km/h, then it should be safe to reach there...
Briggz beat me to it. That's NOT a safe assumption.
Old Jan 13, 2010 | 09:03 AM
Assadi's Avatar
Thanks for the correction no offence taken xD
Chris_Strick
Aug 8, 2013 12:03 PM
firefighter44
Aug 17, 2012 09:37 PM
darkgreen18290
Jan 23, 2011 09:15 AM
bamaboy1626
Nov 16, 2010 08:35 AM
Cusm2012
Mar 23, 2009 06:01 PM
