timing belt
where is the timing belt on an 1998 Honda Accord V6? How often should I change it?
RE: timing belt
i belaive its on the left side of the motor or passager side which ever you pefrer. Anyway i heard the v6 ones last longer but still every 100,000 is always a good idea.
RE: timing belt
is the timing belt visible from just look at the engine? and how often must I change my tranny fluid and spark plugs?? and one more, wats the cheapest, best and easist way to clean the AEM Dryflow filter?? thanks
RE: timing belt
The timing belt is not visible and is not a do it yourself item for most folks. I don't know what the book says but I would change the tranny fluid every 25K-30K miles or more often if it starts to shift roughly. Plugs, I don't know on that model hopefully someone else does. The only approved method of cleaning the AEM dryflow is with their own product. Google it, buy it, use it.
RE: timing belt
if you get timing belt replaced you will probably have the water pump replaced. They are both usually replaced at the same time
