Timing Belt
I replaced my timing and balancer belt yesturday. The car idles and drives perfectly. But now there is a high pitched whinning noise. I'm wondering if i tightened the timing and balancer belt too much. Also there is a slight vibration when i am accelerating. However if im driving at high speeds like on the freeway, it drives and feels fine. Any help would be wonderful. thank you.
RE: Timing Belt
as for the noise yes it could be that you overtighten the belts,,
as for the vibration, if it was not there before the work you performed.. . you could have the balancer shafts out of alignment .. First thing i would do is to double chk all the work you did , there is some write ups with pictures on our DIY section , you might want to take a look there and see if anything looks different of how you installed yours |
RE: Timing Belt
I did the timing belt ,balancer belt and the tensioners on my 99 LX 4 cylinder. I hadone or both belts too tight and there was a whining noise.I just got them adjusted correctly last weekend. It is totally silent now.
Search tensioners and you will find my posts about it. |
