tranny help
I was curious if anyone with a 1997 Accord Lx 2.2 has experienced jumping automatictransmissions? It goes into reverse with a thud and apparently jumps while changing gear... would a transmission additive help? like the lucas stuff... or is it uncureable? There the transmission works fine though... it's a little slow but otherwise those are the only problems. Also, if you tell me to use an additive, how do you get it to the transmission?
Thanks a ton. 1997 Accord Lx 2.2 Auto 208000km |
RE: tranny help
Sounds to me like an engine mount coming loose or coming apart. Check them out first.
Honda autos dont seem to get along with additives. Use genuine dealer ATF, that seems to make a difference. Change ATF by draining then filling thru the dipstick hole. If it's dirty or smells burnt, change it a few timeswith somedriving around inbetween. |
RE: tranny help
Thanks, I just changed both engine mounts a few months ago and i had my mechanic look at the fluid and he said it looked fine.
RE: tranny help
is it "slipping" at all? I'd pull the fuel dipstick out and smell it/inspect it and it wouldn't hurt to drain it and fill it with genuine honda stuff and see if that helps (not a flush just a drain and fill)
RE: tranny help
ORIGINAL: sssexy70 Thanks, I just changed both engine mounts a few months ago... |
